Need Ford 60 spring plate measurement
b454rat
Binghamton NY
Gathering pieces for the eventual SAS, need some measurements using a 78/79 Ford Dana 44 or 60 u bolt plate that goes on top of the spring, not underneath. Don't want to use the stock under axle plates. 2 1/2" wide springs if it matters.
So, what exactly do you need? I really didn't get what you're looking for. Sorry, I'm dumb.
I have a 79 d60 on my 01
http://offroaddesign.com/catalog/Dana60UBoltKits.htm
I get the steel for free, just need the measurements so I can load into plasma then to punch holes. Ford uses plates that go on the bottom, where GM n Dodge goes on top.
Sorry, I'm no help. I'm running coilovers on mine. I know Avery is running one. I'll see if we can get some measurements tonight since I'll probably be at his place
