Need Headlight lever for 1991 Blazer
RJB44
Northern Virginia
My headlight lever is not working, at least to operate the lights. It works fine with directionals. It has cruise control, but that has not worked for years. Looking to replace the lever, since my high beams are stuck on.
If anyone has an extra one that will be compatible with my '91, that would be great.
Thanks,
RJB
[email protected]
Thanks,
RJB
[email protected]
I believe all 84-91 are the same.
The only difference I saw was if they had delay wipers or not.
I have one or 2 I can pull off, do you have delay on your wipers?
The lever should be dependant on delay wipers and also cruise control since that is also in the lever.
The ones I have seen that have delay always had cruise.
I guess that was a level of trim that was a package deal.
