mudbog42
I have been battling these codes for a while now and cannot figure it out, so I have decided to ask for some help. It is a 2003 5.3l flex engine that I swapped into my 86 K-5. I am getting trouble codes p0101 (MAF), p0174, p0171, and the o2 heater malfunction codes.
So far I have tried:
- 3 different MAF sensors no change
-New MAP sensor
-Changed intake gaskets
-Checked over and over again for any vacuum leaks
-Checked grounds to MAF
-Brand new o2 sensors
Also when the truck is cold it moves real slow like it doesn't have enough power to move the truck, then after about 2 minutes it runs and drives perfect.
I disconnected the MAF when it was cold for a quick test and it drove just fine, plenty of power.
I am not sure what else to do here, any help would be greatly appreciated.
-New MAP sensor
