- Joined
- Dec 21, 2016
- Posts
- 1,434
- Reaction score
- 1,448
Need some help.
I've got a 6.0 and 4l80e swapped into an 88burb.
I just installed the TNA mounts and crossmember in the truck. The mounts moved the motor back 1.5 to 2 inches from where it previously was set up. Unfortunately, this is causing lots of problems from exhaust clearance to driveshafts.
The issue I need help with is around the shifters. Neither trans or transfer case shift linkage will work anymore. The transfer case just needs a longer rod. I have a NP208. Can anyone point me in the right direction?
The transmission linkage doesn't line up nice with factory fixed pivot anymore. In addition, the rod from the column no longer reaches. I'm adding a pic of the linkage. I've massaged it a bit to make it closer, but the rod definitely won't reach, and I'm hoping there's a better way. I don't like ghetto, which this feels a lot like.
Thanks in advance.
Thanks in advance.
