Need more info or a part number
hmatiak
Savannah, GA
For the resistor directly behind the air cleaner. Its on a 24v system. Im getting 24v in and 24v out the other side. Also a part number for the correct glow plug relay.
whats involved in swapping over to a 12v system? That would make things much easier anyways.
It's pretty simple... there is a good write up posted in this section if you do a little searching (goverment write up no less).
I converted my M1009 to 12v back in the spring, very easy. :waytogo: Also it is much easier to get an alt or starter for a 12v truck when you are on the road.
