Most of the responses you've already gotten are on the mark...
As you've probably figured out, the cable lockers are NOT an Ox-Locker, they are the original factory setup. Simple, mechanical linkages create a fully locked axle on both front and rear....user-selectable. Very nice.
Wide 6-lug pattern is odd....IIRC, Mogs came with 20" wheels from the factory, so that's probably the easiest (pronounced: cheapest) way to go. Conversion kits for 8-Lug Chevy are out there.....but they cost big money.
Pinion conversions are required to connect to standard driveshafts....about $200 ea from what I've seen.
Gearing is only available in one flavor (DEEP!).....it's 7.56:1, take it or leave it. Great for crawling, lousy for the highway.....no amount of tire is going to tame a gear that deep on the highway either. Either drive at low speed, trailer it, or spend the money on a 50% overdrive setup.
Clearance - You gain about 6 inches of pumpkin clearance over a conventional set of 1-Tons. That means that a 38" tire w/Mogs has the same clearance as a 44's on 1-Tons. It's sweet. The problem is that the axle tubes are 6" higher than usual and there will be all sorts of frame interferences (and oilpan!) unless you run a LOT of lift or go full-custom and do a buggy chassis instead.
Steering - You'll need some. It's probably going to be custom too...Mogs are set up with the tie rod behind the axle, which probably won't work due to clearance issues. Plan on designing something from scratch that has better Ackermann for your wheelbase.
38377k5 said:
The main weakpoint is the portal boxes. People break both the portal boxes themselves and the portal gears. Replacements are hard to come by and expensive. There really is no upgrade.
Not true! The portals
are a noted weak link in the Mog404s, but it's been addressed. Some guys have laser-cut a horseshoe shaped reinforcement and welded it to the backing plate area to stiffen the box. A company called MSI is also offering completely CNC machined portal housings to replace the factory parts...... yes, they're expensive......REALLY expensive. But purdy!
BOTTOM LINE:
Mog axles are really cool.....but not a cheap solution. Certainly a LOT more expensive than a conventional 1-Ton swap. Definitely do some research on the costs for converting to 8-lug, pinions, etc. before you start, and then decide if you still think it's worth it.
