Ned Kelly
I'm sure some have seen this article. Neat idea on making a simple pan modification so that you never overfill your TH400. See 3rd picture and caption from the top of the page:
http://www.carcraft.com/techarticles/ccrp_0611_1955_chevy_transmission_rebuild/index.html
I think I'd like to insall something like this in my pan. Any ideas for components?
EDIT: Some text from above link:
Kilgore came up with a very simple solution to this dilemma after witnessing multiple oil-level-related trans problems. Kilgore integrates an oil-fill standpipe into the oil pan's drain plug. Anytime the fluid is drained, the refill procedure is to add ATF until oil begins to dribble out of the tube. With the engine running, shift the trans through Reverse and Drive a couple of times to ensure the converter and valvebody both are properly filled. Check the level again and fill until oil dribbles out the standpipe again. Then the pipe is plugged and you're ready to race.
