It's a nice transmission. A guy here at work just went from from an '02 2500HD/6.0L/4L80 to a virtually identical '08/6.0L/6L80 version and pulls a larger camper all over the country. He really likes the new trans as the towing performance is better in the mountains both uphill and downhill because of more gears (he said it never shifted into 6th while towing...which is just a really high overdrive).
Empty it really helps fuel economy because combining the higher 6th gear overdrive and higher 3.73 axle it really drops the cruising rpm down, while still having more low-end grunt than a 4l80/4.10 axle truck.
Transmission gives you six forward gears (2.97, 2.31, 1.57, 1.18, 1.00, 0.75)
Looks like it has the same OD as a 4L80e, just has a few more gears between first and overdrive. The big upside of course is you can work with a much narrower rpm range to get the same job done.
Rene
who makes the controller for them? Last I heard there was a company working on developing a stand alone controller, but hadnt heard anything since then.I daily drive a 6l80e There is after market controllers for them. I know a little bit about them, what in particular are you looking to hear about?
The overall length of the 6L80 transmission is actually SHORTER than the 4L60E! We had to use a longer driveshaft for this project. The 6L90 is 35mm longer than the 6L80 due to the thicker gears, etc.
Note to self: after winning lottery, purchase 6L90E.
