After replacing a bad drag link end and wheel bearings, my steering has tightened up significantly...however it still has a little "drift" to it.
Will new leaf springs fix this feeling?
or do I need to go ahead and put a new damper on, new sway bar bushings?
What will tighten everything up and make it ride and drive the way it came from the factory?
By the way, it is factory with no lift.
