Thinking about new seats for the K5. Who makes direct fit seats? I basically want to remove the old, bolt in the new without modification. Also – is there any other GM make/models that are a direct bolt in fit?
Almost bolt in. If you can cut some flat plate steel and drill a couple holes in it, they'll bolt in using the stock front mounting holes on both sides.
