CK5 Forums
Take a few seconds to register your free account to post topics or questions, and view exclusive content!
new SUPER SEALER trailer build : NEW TOOLS TODAY !
sweetk30
I build stuff
Premium Member
horseheads , ny 14845
Got my swivel wheel kit for the front of the blower today . WOW what an improvment in user comfort using it now . The front wheel can lock straight and or unlock for 360* movement.
Then i was able finish the hook system to secure it down like the tar buggy .
sweetk30
I build stuff
Premium Member
i saw a little trick years ago on doing it with ZERO burn out .
weld the puddle on the surface and then dab in/out of the expanded and it will flow in great and unless you hang out to long you get no burn threw .
sweetk30
I build stuff
Premium Member
Did a test pull around the block today . . . She tows like a dream atleast for a full block . Didnt hardly know it was back there .
Was able to do a timed test for the rear gate and equipment unload and load test 1 man . I can get them unstrapped and gate down and both off in around 45 sec . Then i can reload strap crank and pin gate in about 2 min . This design worked out so good .
Got my road cone place figured out today also . There is 15 of the 18" tall cones there . And the front trailer jack is bonus point for 5 cones we will use every day for traffic control on each site.
The trailer is hanging in the air now to finish a few welds on the bottom side . It has a engine hoist on the tounge and trans jack under the back for extra security . And i have a helper in the shop these past few days .
sweetk30
I build stuff
Premium Member
Finished up a few welds this morning on the underside . I loked the top of the rail expanded metal so i added it to the rest of the rails .
sweetk30
I build stuff
Premium Member
Finishing fine details . Had to replace the tank lift jack . It blew up and died . But no biggy as it was a free one i had got . So i went and got a brand new 3,500 lbs jack and now she cranks like butter on a hot knife .
Started the lighting and wire layout . Got a solid plan and cant wait for a test light off as i am doing a little different layout . I got a 2 wire to 3 wire converter box so i can have specific brake / tail / turn light combo . I did swap the white backup for amber for the turns .
sweetk30
I build stuff
Premium Member
takes the brake & turn of a 2 wire system and splits it for a brake / turn separate 3 wire system .
under 30 bucks from curt hitches . part #56196 https://www.curtmfg.com/part/56196
yesterday half day and the rest today i have been building the complete wiring system for this trailer from the pre-molded plug and 8ft wire and junction box / break away switch / battery for break away / main wire to rear 2nd junction box / both sup harnesses for lights / break wires to junction box . lots of work but its all clean & secure & 100% sealed ground / isolated in the wiring . . . NO direct frame ground .
sweetk30
I build stuff
Premium Member
got it wired for lights today and did a test run .
i have :
tail lights and side markers = CHECK
brake lights = CHECK
left & right turn = CHECK
but if i do brake and a specific turn together i get 1-2 slow turns then no turn after until i let off the brake . also the 4 way dosnt do the amber bulbs it does the brake / tail red's i think thats the way the truck is wired tho .
i fired off a tech support email to curt on this and hope to here back monday or tuesday .
sweetk30
I build stuff
Premium Member
so i need to go back to normal lighting system on the trailer for now .
i talked with curt on the phone 2 times today . the first tech guy had no clue and or didnt even know the product i was talking about . the 2nd guy was super smart and understood exactly what i wanted to do and he had tried it before and it was a no go for him also . he did say there was options out there but wasnt 100% sure who had them and if they would work .
so to get this thing rolling i am going back to std bulb setup wiring for now .
@mrk5
sweetk30
I build stuff
Premium Member
so today i swapped the lights out for 4 led units / flip flopped the wires around for normal function / removed the shit box unit that wont work / started doing electric brake wires and front and rear side / corner markers . i have almost all items checked off this list from my state DMV page on required items .
once its all wired and tested i need to paint it and reflective sticker it . after that i need to do this page for trailers OVER 1,000 LBS empty to file for a homemade title and state provided vin# they put on .
if it all passes after that then its just a registration and plate fee and get rolling down the road .
sweetk30
I build stuff
Premium Member
Did the 6" x 6" white and red dot reflective tape today .
Then i went to the dmv to get the 4part carbon copy form you cant print off line to let me start my vin# prossess going . Then i had to dig out my paper work for all parts to build the trailer . The stack is about 2" thick for all bill invoices for when they ask .
imiceman44
Hoarder extraordinaire
Premium Member
Lincoln, CA
Ii don't produce everything.
The more you give them the more they tax you.
sweetk30
I build stuff
Premium Member
Checked the other day and dmv section i need is about 2weeks behind on paper work prossess time . She is ready to go to the inspection site just need the time & date. :popcorn:
