*NEW* Waterproof Fuse Blocks - Twizted Engineering
TwiztedEngineering
Broomfield, CO
For anyone who has a vehicle that is open to the elements, or washes out their interior...
We have put together a "kit" package of a waterproof 20-position fuse block (2 sections of 10 fuses each) that takes the newer mini fuses. Comes with crimp-on wire terminals, wire seals (for where your output wires exit the fuse block) and even a few "plugs" in case you don't use all of the positions! We also have the high-quality crimping tools available that will not only crimp the terminals but also crimp the wire seals properly.
$95.00 - Fuse Block Kit: http://www.twiztedengineering.com/servlet/the-47/Waterproof-Fuse-Block/Detail
$65.00 - Crimping Tool: http://www.twiztedengineering.com/servlet/the-48/Crimping-Crimp-Tool-Terminal/Detail
-Darren
sweet is there a central power input or individual can you take a pic of the back side.
I already sold the first "kit" I put together and took pics of - didn't figure I would sell it so quickly! So I can't take a pic of the backside, but I can tell you that there are two input posts - one per each bank of 10 fuses. So you don't have to wire power to each individual fuse, but you can still separate it into "constant power" and "ignition switched" power!
-Darren
