After finally fixing the cooling issue, It stayed 172-174 for about 10-15 minutes of driving. Was feeling pretty damn good driving it again. Then I started to lose power. Hard to explain but it felt like it was going up a steep hill with no power left in the engine but this was on level roads or going down hill. Stopped, let it cool off for 20 minutes. Checked all the vitals- oil, antifreeze, trans oil, tune, etc. No shavings in oil. Everything looked good.
Got back in it, drove for another 3 miles. Was normal at first then it happened again, no power. Struggling just to drive down a street that was slightly downhill. So weird. Was in 3rd, lost speed, then I downshifted in 2nd, still losing speed. Finally pulled over in a neighbor hood a mile away from house. Temp was 190. I have a 160 thermostat.
Walked home, let it cool off for an hour, then went back and it drives fine going back home for that 1 mile. Definitely something to do with heat. Oil pressure is normal at 35psi at idle. Goes up with RPM.
Specs:
Freshly built 406 SBC, Dart block, AFR heads, Edlebrock PF4 EFI, 4L80 with manual valve body. Engine should have plenty of power with the mods.
Possible causes:
-Edelbrock PF4 still not dialed in. Could be something there in the tune that I'm missing. Something to do with the pump? I forgot to look at the fuel pressure when this happened. Its normal now in the garage when at 190 temp. Fuel filter is new.
-Something in the engine. Valves too tight? rings expanding too much? bearings?
-4L80 trans acting up, could be overheating. Need to put a temp gauge on it. Could be built wrong.
Has anyone had this happen on a new engine build or transmission?
Specs:
Possible causes:
