I checked the ignition switch. Truck has manual tranny, so I don't think it has a safety switch. I there a switch that detects fuel pressure then allows power to starter? I notice that the fuel pump runs at least 10 sec, then shuts off. Should run 2-3 I think. Nothing changed on TBI except new frame mounted fuel pump. Fuel at pump on tank side for sure. I'll check for fuel at the TBI. Is it possible I hooked the fuel lines up backwards? Just to check...my return line is on the passenger side of the throttle body and the feed line is on the driver side. Can someone verfiy this? I know its something simple, because it ran fine when when I took it down for a re-build. Paul
