Vehicle in question is a 1985 M1009 CUCV (K5) with a gas 350 and 12 volt conversion.
I have had no such issues in the 3 months or so that I've owned this truck so far. She can be a pain to start but patience and gentle manipulation of the manual choke usually coax the engine to life rather quickly.
I've decided to put the ideas I've found/my options in bold for quick reference.
Took a ride out in the old girl yesterday to get 'er measured for new hydraulic plow hoses. All was well until ascending a relatively steep, but short, grade near home. The engine started hesitating, never stalling out, never sounding really "bad", just got sloppy and lost some power as I went up the hill. Gently trying to give it more gas made no difference.
Got over the hill and all seemed back to normal.
My driveway slopes uphill toward where I park this beast, and I've never had a problem with that, including yesterday. Drove right up the driveway and parked. No hesitation, nothing unusual.
Yesterday I went out to start 'er up, and it wouldn't catch. Starter sounds normal but the engine barely engaged. I got a few rumbles out of it as if it was about to start normally, but it never started.
Went online, people mentioned new plug wires and fuel filter as simple concerns. I always believe in starting with the simple and cheap things to fix. My plug wires (and plugs) are nearly new, honestly less than 25 miles on them, and my fuel filter has perhaps 50 miles on it. Those are some of the first things I changed when I got the vehicle.
A friend of mine said maybe there is condensation in the gas tank. Now, let me say here, I do not know for sure how accurate the fuel gauge is. The previous owner said it is, but I take that with a grain of salt. The tank read "full" when I got the vehicle. I have not added gas and it shows half a tank now. So the gas is roughly 2 months old or more. I bought two bottles of Heet gas drying alcohol stuff, and put those in the tank yesterday. I was told it may take a couple of days to work. With a snowstorm imminent within the next day or so, I want this truck to plow, so just now I tried starting it again, and no luck. The Heet has been in my tank roughly 16 hours. For what it's worth, most people in the area buy the ethanol gas at the major gas stations, so I would imagine the previous owner did.
Did some more reading online. Perhaps the position it is parked in is the problem? The nose of the vehicle points slightly uphill. It seems that may promote air creeping into the fuel system. Have never had that problem with any modern fuel-injected vehicles I've owned in the same driveway, so it may be the case with this one.
I cranked and cranked until my hand hurt from holding the key forward, and the battery sounded nearly dead (it is on a 10A charger now). The darn thing still doesn't want to start. I was thinking of getting 5gal of ethanol-free gas to see if that might be all it is thirsty for.
I would love to move the truck to level ground and try to start it, however I can't because if I rolled it backwards (down a slight hill), it would block a shared driveway, as well as block me in, if it didn't start. This is a narrow (heavy tree cover), rural, dirt driveway and I don't think a tow could be easily done if the vehicle got stuck there. Then again I have seen some miraculous towing done as I've worked in law enforcement and fire/rescue for many years.
What are your thoughts?
