- Joined
- Mar 3, 2000
- Posts
- 9,123
- Reaction score
- 7,077
78 Ford F-150, getting no turning out of the speedometer drive gear in the T-case. Everything else is new: speedo gear and clip on end of speedo cable, speedo cable, Speedometer.
So gear is still in place in T-case but nothing happening on speedo when driving. If I take the cable off at the T-case I can turn the gear on the cable and make the speedo move. I have never taken this T-case apart, looks like you could take rear drive shaft and yoke off and the housing behind it. I am wondering then if the drive gear just slides off a shaft or how it is connected in there? No other problems noticeable in T-case.
400 engine, 4 speed manual, looks like NP 205, all original to vehicle.
Speedo was working, body shop cut through cable or at least partway, they drove it then speedo wouldn't work. They replaced cable still no work. I replaced everything, speedo, cable, gear, clip and this is where I am at. Drive gear feels ok but can't feel all of it, maybe worn tough to see it well.
