Yes, you would need to upgrade to a 32 spline front output to run a 1350 U Joint or CV. The stock 30 spline flange uses the 3R CV which is decent but my suspension was beyond it's working limits. It is about the same strength as a 1330 from what my driveshaft guy told me.
Here is some 32 spline swap info I posted up on pirate a while back from when I did mine...
Just swapped my 30 spline front out put over to a 32 spline out of a dodge and thought I would share some info.
First off I thought I might need a different front roller bearing but they are interchangeable.
The thrust washer is also interchangeable
Spicer 1350 yoke part number 3-4-6211-1 (my dealer said they no longer make yokes for "U" bolts? I dunno maybe bull****)
Spicer 1410 yoke part number 3-4-10951-1
National seal # 473468
Must get the 32 spline spline seal though, normally included in a seal set.
