If I ever rebuild the 350 engine on the K5 will the rebuild process erase any of the numbers stamped on the block?
My K5 is numbers matching engine and tranny. I replaced the np203 with a np205 but I still have the original np203 from the k5 sitting on the floor.
I also wonder if I should remove the original 350 and install another 350 so that the original engine can remain relatively low miles. About 120K miles.
