You guys that have done this swap, how did you deal with relocating the floor penetrations? (assuming non removable tunnel)
I'm seeing a couple of options.
1. cut a big hole, weld it back in after with the holes in the right place.
2. cut a big hole, make it removable with the holes in the right place.
I'm curious to know what others did.
My setup is NV4500/NP205. I'm going with the 1.625 thick AA spacer to mount my long input tcase and an ORD Twin Stick shifter.
