Off road option
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by pr1aw, Sep 30, 2000.
  1. pr1aw
    pr1aw 1/2 ton status
    Sep 17, 2000
    144
    San Diego CA
    My 91 has the off road option with 31x10.5, did these come with a little higher lift, it looks like I can put 33's on with no mods, but I haven't taken it out to see what the flex is like since I got it a month or so ago.
  2. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    pr1aw,
    My '90 Jimmy came with the same option's. It has the towing package, etc. I purchased a 4" lift and 33x12.5x15 on 10" rims. Naturally I tried putting the tires on prior to recieving the lift. The rear fit fine, might have hit at full flex. The fronts fit, but would not clear in a turn or flexing. I have read posts of people who say they are running 33's with no suspension modifications, you might try to borrow a couple of tires and bolt them up and take a look.
  3. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    why not try 32 inch tires? They fit nicely.. and no rubbing. Look pretty beefy too.
    It's better to have it and not need it. Than to need it and not have it !
  4. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    when i put 33s, as mentioned above they rubbed on full turn. when i took the truck to get painted, i got them to cut the fender, then reweld the lip back on after the cut. it looks real nice, you can only tell the fenders have been hacked if you park 2 k5s next to each other, it looks totally stock.
    Knife.
    knife.coloradok5.com
