Oil on Valve Covers & PCV Valve
jeff in co
Colorado Springs
So, what do these pictures mean? Leaks/PCV valve replacement??
I just redid the valve covers last summer and the engine compartment is usually kept pretty clean.
Is it a sign of too high of oil pressure? :dunno:
You sure it's not just the seal/gasket on the oil filler?
I'm not sure, but there should only be a PCV on one side. The other side should be where the air is drawn in, probably through the air cleaner housing.
You might try replacing the PCV itself. If you lose suction you may be more prone to leaks. Just throwing out ideas here.
Tag for updates since I have the same problem on my somewhat recently rebuilt 350.
what's the mileage on the mill? how's the blowby?
Truck has 341k on it but the engine was replaced at one point. I don't know when that happened so hard to tell.
It does not use much oil in 3,000 miles (maybe 1/2 quart) and does not excessively blow any smoke on cold startups.....
that's not blowby.... leaving the pcv hooked to the hose.. pull it out of the vc hole while the engine is running.... how much smoke is coming out the vc hole? blowby is cylinder pressure being forced into the crankcase, it will often push oil residue past pcv and filler grommets on higher mileage motors...
Looks like seepage from the bolt holes/seals and that rubber grommet for the pcv gets hard over time, not sealing too well. to me. Had similar crap on the original engine in the burb. I just cleaned them off now and then because I knew the engine was getting replaced soon.
Did this just happen that you know for sure or are you just noticing it? It doesn't look super wet from the pics.
Take the oil cap off and see if it's blowing out excessive. My 322,000 rangers got some blow by but not enough to blow oil onto the engine.
New PVC and grommets first,.
No, it's probably been doing for awhile....just noticed it because its been parked for a little bit. I'll try replacing the grommet, oil cap and PCV valve for now, and see what happens.
