Dorman 610-188
Dorman 610-189
Dorman 610-288
I should check which ones I have, they might work for you. I took someone elses advice, and now I have a set with too small of a knurl for the hole I drilled.......
Martin
Dorman 610-188
Dorman 610-189
Dorman 610-288
I was thinking about picking some of those up but the ones I have installed now leave enough thread showing for my comfort.I'm running rear dually studs on my front and rear axles. Plenty of threads with them.
It wasn't happening with these ones lol, that .002 extra on the knurl of these studs made a huge difference vs. the stock one in terms of getting them in there.I always use two flat washers and a regular nut to pull the studs through. Just put a little antisieze between the washers and hit it with the impact.
Thanks man, have to get it moving under it's own power in the next few months, hopefully things will pick up soon.Nice progress!
Just an FYI the crankshaft was different in the older 6.0's... Idk what year GM switched things up but the crankshaft spacing is different and idk what the parts recipe is for one of those engines but it is different.Dude I'm glad I found this build. an lq4 swap might be in my future with keeping the 465.
