Your center pins look way far forward of your bumpstops.?! Nvrmnd. I just read that you wanted to shorten the wheelbase.
Longer leaf springs would fix thatWell I got the brackets bolted on, got lucky and didn't screw up any of the new holes that were made.
Got the rubber bushings and sleeves out of the 60" springs.
Got the poly bushings out of the 56's without tearing them up and transplanted into the 60's.
Went to hang the first spring and my shackle is the wrong way lol.
If it stops raining I'm gonna get the 14 bolt bolted back up to the new springs then flip the shackle flip opposite sides. My shackle angle should be vertical at that point (no weight in the rear).
Fuel and a spare, hi lift,....Flipped the shackle flips yesterday, shackles were close to vertical but still pointing towards the front of the truck.
Picked up some 63's today, came off of an '03 2500, 4 leaves + overload. Just racking up leaf springs.... gonna have a good selection for bastard packs I guess.
Slapped them on to see shackle angle, put a jacket right under where the center pin is and put enough pressure on it to lift that frame rail off of the kickstand a hair.
Not sure what it's gonna look like with 180 lbs. of fuel sitting back there.
I can flip the shackle flip back around or drop to a 4" shackle (which I already have sitting around from an old project). Any advice here?
And my toolbox full of stuff...Fuel and a spare, hi lift,....
Reshackle flip huh?
Gonna throw the spare, my toolbox and my 3 kids on there. Should be close.Practice makes perfect. Have some of your buddys stand on the frame or stack a bunch of crap on there to simulate the load
Man... I've got it down to a science lol.You should be good at spring bushings with all those springs.
