Old Iron 2.0
Got her put back together. Looks pretty level front to rear.
Wheelbase is 128.5"
Shackle angle look too steep? Would dropping down to a 4" shackle bring it more vertical? Has 6" shackle on it now.
Pretty sure 150 is correct for grade 8 5/8" ubolts. Yep several sites say 132-177 for grade 8. I always go 150.
That's what I've always done. I believe I got that number from some stuff that ORD sent me back in '13 when I first got into these trucks. Bought a whole lift kit from them for my long gone '76 SWB. Been doing 150 lbs. since then.
That's what I read too, then I had them come loose.
I give them hell with an impact and give them more with a large breaker bar. Ruffstuff bolts, nuts and plates.....
I haven't had any issues in the past but I'll keep an eye on em. Having no bed makes it easy to check on them lol.
I have Ruffstuff plates, ORD bolts/nuts.
Did you open the center pin hole on your Ruffstuff plates up? The holes in mine were 9/16" and I had to open them up to 3/4" to clear the center pin nut.
no, I just run the bolt through to the top of the springplate.
here's a read about u-bolts from a couple years ago https://ck5.com/forums/threads/check-your-u-bolts.316885/
Drive shaft is a few inches long now. Thinking about cutting it down myself with the sawzall then taking it to a driveline shop to have it welded back together and balanced.
Guessing it can't cost too much if I go that route.
let them cut it down correctly otherwise they'll be charging you more. It cost me $100 to cut down my last shaft and re-balance it.
Is there a special method they use to cut it?
correct and where to cut it. Give them a call and get the measurements they want.
Just looked through that thread. That f**kin blows... I'll keep an eye on mine for sure.
Bottom line, keep an eye on them. On my shakedown run a couple weeks ago I checked mine a couple times.
Typically fine thread goes to a higher torque value, around 150 -160 is good for coarse thread, somewhere around 180 is standard for 5/8 fine. Either way as long as you are keeping an eye on them, and like you said it is a lot easier to check with no bed on the truck.
I need to order a rag joint for a 2wd box, the one off of my 4wd box measures around .75", the 2wd input shaft measures around .50".
I need to order the brace that connects the core support to the balance too.
Dont use a rag joint. Use and XJ shaft or a Flaming River ujoint coupler
Are all of the steering column ends on our truck the same? The part where the steering shaft bolts up?
If so I'll be using a Chevy Express shaft like I did on the K5 way earlier in this thread.
