The one wheel cylinder was plugged up.
Still changed the lines on the rear axle for the fug of it. One was too short so it got crappy temp run.
Still has an issue in my opinion though.
I got fluid out of every bleeder. Many, many bubbles. Lol.
But..... When I push the pedal back and forth I can see fluid moving forward and back in the bleeder tube. But with a bleeder ANYWHERE open, it should drop the pedal to the floor.
Plus, pushing the pedal should shoot fluid through.
Has on everything else I've ever bled
With either rear bleeder open the fluid moves but moves SLOW. And the pedal gets pretty hard about half way through.
Open a front, straight to the floor.
I'll see how it actually acts on the road I guess.
Transmission filter is changed. But I may have messed up and over filled..?
I read 4 posts in random forums about how to refill after a filter swap in a th350, and every one of them said start with 4 quarts, and add from there.
I only drained 3 out, but didn't realize that until I was done and putting the old in the new jug. It was full before I drove the 1.5 mile to the shop.
I'll see when I can run it tomorrow I guess.
Oil fluid and filter changed too.
All shocks done, so it's pretty much ready for a test drive. Only thing I have to do is tie the muffler away from the driveshaft.
New muffler will be here Thursday, and I'll fix the pipe then.
I have new spark plug wires, but I'm going to wait a pay check and get plugs and a cap set while I'm at it.
