I was having a conversation with a friend. He told me to swap out the 700r4 with a TH400 (since I already have it). I had a little bit of a discussion in another thread in here but this is to directly to the point. No picking through the original posts main points first and all that. Anyway.....
The 700r4 has OD so gas mileage will be better but gas mileage isn't a big issue. If it was I would be driving a 4 banger. However, it is one part of the equation. Strength is the other part. The TH400 being stronger.
Then you got the 241 with a lower bottom gear then the TH400. I figured there is much more experience here to help make a determination.
Okay. So what would you all suggest...those of you who have used both, hopefully.
I have or will have when I am done "K5, 454tbi, 6" lift, 38s or 40s on H1s, NP241 (could use a 205), D60/D70 DRW with 4.88 gears"
Slip yoke eliminated, Chain eliminated and 3 low ranges to choose from. The money saved fom not having to beef up the trans will go towards the cases. A stock TH400 should be fine behind a TBI 454.
