william_7900
Registered Member
I have a 350 in my 71' Blazer but it has absolutely no guts... It doesn't smoke but just doesn't turn the tires very well. I am running 4.11 gears with 35" tires (even with 33's it doesn't have much umph....).
I don't want to change the gears because i don't want to be running a 3000 RPM's at 65 or 70...
I swapped in an NV4500 5 speed tranny a few years ago. Also it has a new carb.
What are the negatives of doing this swap and what must I change? (added weight, things that will twist up behind a 454 that wouldn't with the 350, differences in torque etc...)
I'm mostly interested in just making the thing fun to drive again...
I swapped a 360 into one of my Jeeps back when i was a Jeep guy and it made a huge difference in just general drivability - I'm hoping for the same if i swap in a 454...
Thanks for the feedback and help.
William
William
(luckily that one was warrantied and I got my money back and applied it to 1 ton stuff). All of this was on the street, but I can't say I was easy on it (you know, 18 year olds with 400 hp
