WJACKSON11X
I recently removed the steering box brace off of my Jimmy to install on my Suburban. Both are 4wd. The frame mount with the single bolt doesn't even come close to lining up after I drilled the crossmember. I used the Jimmy for rockcrawling, so is it possible that the brace is bent? It sits off the crossmember a good bit and doesn't line up. I tried to cycle the steering with the wheels on the ground to try and flex the frame. Although it got closer, there was no way to get the bolt in.
I know i could drill a new hole, but that seems like it would hurt its effectiveness. Anybody have this issue?
