Sold ORD Triple stick for doubler
rderosier
Colorado Springs, CO
Discovered this won't work for my setup with a transmission swap so hoping to recoup some cost. I'm not sure it was ever actually used, it was bolted on and has paint over spray from the doubler being painted I think but the boots are brand new as well as the plates for them. All the bolts and brackets are there (not shown is what's still bolted on the doubler because I haven't pulled it off yet. All that's missing is shift knobs that somehow got lost in a pile of parts I guess.
100+shipping? Obo
What transmission was this ordered for?
I’m interested in this......though I’m unsure if it will work with my transmission. I’m using a 4L80, but I don’t understand why the transmission is a factor?
The part circled in red bolts to the adapter where the transmission attaches to doubler. The adapter on the 4l60e that I use has fins that get in the way so I couldnt use the triple stick. I called ORD and they didn't make a bracket for my application, it might be worth giving them a call and see if there is one for your application, I'm sure they'd sell you just the bracket if that's the case. 20200517_230949.jpg
Thanks.....I’ll look into it! That’s kind of what I was thinking the connection was but wasn’t sure.
My trans/t-case adapter came off a TH400 so I think it should work.
Send me your PayPal info. My zip code is 93611 if you can figure out the shipping please.
