Ordered up a front lockright!! (update, DONE, PICS!)
Re: Ordered up a front lockright!!
Hey all you open diff'ed tractionless bastards: /forums/images/graemlins/rotfl.gif
Feast your eyes on this....
TRACTION!!!!
Ordered it Thursday, got it today! Great shipping time. /forums/images/graemlins/thumb.gif
Ah, I remember the day when I got my LockRights. I was so excited I couldn't hardly contain myself. And I had to wait several days before I could put them in.
It's kind of funny, ours have the same number of teeth yet yours is quite a bit bigger than mine.
Tim if you thought x-over was awsome you will need a rag on your seat with you when you drive a fully locked 4x4. It is another one of those "I don't know how I did this before?" type of things. /forums/images/graemlins/waytogo.gif /forums/images/graemlins/woot.gif
In case you haven't installed one read the D60 tech article on the mainpage as removing the cross shaft in the carrier is different in 60's. (need a long thin punch). It took me a good hour of cussing and twistin before I looked up the info and made a punch (read cut the tip off of a long cheap japanese screwdriver). If this is old news don't be offended as I wanted it to be here to help somebody like myself in the future.
Enjoy the true 4wd feeling.
get it installed i wanna hear how you like it!
Tbanks for the tip, I've been dreading the roll pin. I'll be installing it this weekend.
What article covers this on this page?
Here ya go www.coloradok5.com/dana60manual
And here it the actual picture of the carrier removal
The top right picture shows the x-shaft pin deal. The caption on the following intallation page is wrong. On most 60's the lock pin is a punch fit, not a screw. Hope this helps. I scored a 1985 (publishing date not vehicle date) chiltons for $8 at a local thrift store and it help out immensely. (the early chiltons make little reference to specialty $$ tools, just a lot of hammers and punches)
Oh, if you have 4.10 gears and higher you should be able to intall the whole thing with it in the axle (at least that is how mine worked out)
I know how to get the carrier out that's no biggie.
I just wondered exactly how long this punch needs to be to drive the roll pin out. Will it come out with a regular 1/4" drift?
IIRC, it needs to be something like 1/8" and about 4-5" long to push it all the way out from the ring side. A standard punch in that size is not going to be long enough, at least mine was not.
Hmm. 1/8" and 5" long? Where am I going to find something like that?
Screwdriver. Craftsman philips screwdrivers are about perfect to be used as punches. Once the head strips out I cut the end off and use them for punches. Once the handle is all monkeyed up, I break the shank and then have it replaced.
Craftsman screwdrivers are junk anyway, they're like condoms, use them once and throw them away. I've shattered countless flat screwdrivers, one time it cut my eyelid when I was taking mudflaps off my truck. And I was only using one hand. Every year I buy a new box of the 21 or 27 set screwdrivers. But I digress.
I destroy craftsman stuff on a regular basis too. I don't give a rat's ass, I just take it in and they replace it.
Using a #2 screwdriver with the end ground off sounds like a great idea. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
I dunno what it is about the D60, but everything that used to be easy about working on the front axle is now history, with the only exception being that the knuckles and steering arm can be easily removed.
The bendix style calipers and that stupid roll pin are among some of the stupidist ideas I've seen to date.
This project is DONE.
http://community.webshots.com/album/139332581EWiDZS
The driver's side axle shaft MUST be pulled to install this. even with them all the way outboard, I could not get it together.
VERY easy install. Unfortunately no action shots of using it yet, that's going ot be tomorrow I hope!
My power steering hates me. /forums/images/graemlins/rotfl.gif
what part of the calipers is it that causes you grief?
other then they were designed for larger diameter tires I never have any troubles with them
in fact I prefer them over the total crap that chev used on just about every other application
only upgrade I can see would be a fixed caliper design
congrats on the upgrades
I just think that the 10 bolt/D44 setup is much simpler.
None of it causes me grief, just with all the grinding I had to get into the little piece of hardware that holds in the caliper so if it was bolts like the 10 bolt/44 it wouldn't have that problem.
That said I wouldn't trade my huge brakes for any crap off a D44/10 bolt. Much nicer to have big brakes with big tires.
