katugly
So i was replacing the pinion seal on my 10 bolt today and over crushed the sleeve. In theory if I get a new sleeve and go back to my original thread count and marks will my preload be correct?
Second question I have never tore into any diffs before and am unsure about the carrier. If i just pull it out and make sure to get all the shims and such back in the correct spot I don't need to re setup the gears correct? If I don't have a place to start with the crush sleeve what is the correct inch pounds for the preload on the pinion? I'm really out of my element with axle ****e.
old gm tech told me this works like a champ.
havent had one go bad yet.
