johnpaul mack
Registered Member
UPDATE! A FEW PRICE UPDATES. (Note- I have been away from the scene for awhile so if you have issues or questions about my prices please private message me so I can correct the issue thanks) also all prices are OBO.
2. NP 203 range box $50 (also have a few other parts from this case)
3. ord np203 twin stick, powder coated black, dose come with boots (can be used with doubler according to the web site)- $100
4. NP 205 27 spline input figure 8 pattern, disassembled cleaned and inspected and dry assembled, just needs gaskets (was planing to do a doubler) have oe shifter for is as well. does not come with adapter.-$100
5. NP 205 to TH350 27 spline figure 8 Adapter- $50
6. Np203 to th350 adaptor - $50
7. Rough country ez ride 4" lift springs and 1" zero rates -$150 for both
10. 56" rear springs 7leaves and 1 over load and 1" zero rates $100 for both (surface rusty from sitting)
11. 2wd steering box (had some seeping at pinion shaft -$40
12. ord bent drag link for cross over with used but good ends $60
13. Black widow heavy dutty tie rod (1.5" if i remember right) with used but good ends $60
14. wfo dana 44 cross over steering arm 1.5" tall, comes with stud and cones and nuts, fits draglink ends es2026r and es2027l -$60
15. pitman arm for cross over, $25
19. Full set of auto meter procomp gauges. Fuel level, oil pressure, volts, water temp, trans temp, 5"tach, 5" mech speedo. will come with senders except for the fuel level sender as the gauge works with the stock gm one. And NIB lokar speedo cut to fit cable. All on good shap abd work. However the tach and speedo have a little light scuffing on trim ring and the speedo needle paint is cracking and may flake but has not yet. -asking $500obo
20. Summit racing dual port heater believe it is 40000 btu ( removed stock heater/ac)
Also comes with fire wall pass through fitings.- $80
22. Topper in great shape no cracks black out side red inside. Newer seals last time it was off. $100(whats it worth?)
23. Lmc head lamp relay harness. $20
24. Any part of the factory wiring harness...make offer for what you need
25. Head lamp switch. $10
26. Wiper switch. $10
27. Wiper motor $35
32. Frame brackets parts and pieces-make offer.
33. Rear topper sliding windows - they need tlc and wing windows missing. $100 for the pair. Perfer not to ship glass.
35. Front and rear drive shafts. Rear shaft has convertion joint for 14bolt. $40each.
36. Headman headers for sbc freshly bead blasted ready for paint. $80
37. New in the box transgo th350 shift kit.$30
38. glove box $40obo
39. Brushed aluminum right side dash panel $20obo
