y5mgisi
1 ton status
Im going to be replacing the body mounts on my 78 this weekend. Here's how i plan on going about it, loosen all the body mount bolts, remove driver side body mount bolts, jack up driver side from the rocker area, old mounts out/new mounts in, lower driver side back down, loosely instal driver side bolts, remove passenger side bolts, etc, etc, then tighten all the bolts. Sounds good? Should i need to disconnect anything (brake lines, steering shaft, wires) to gain the amount of clearance that i will need to pull the old bushings out and put the new in?
