Play in np205 output
88k5blazin
clark new jersey
I crawled under the beast today and noticed that there is a little bit of play on the output yoke of my np205 going to the rear driveshaft. That joints are all snug it is the actual yoke going into the back of the case that has the play. Any ideas where the slop would be coming from? Thanks
In and out, or round and round?
There are several gears in there each with a little play between the teeth. It adds up. After a few thousand miles, its not uncommon for there to be 1/8 of a turn or so.
If its been a while since you changed the oil, try letting it sit for a while and then drain it.
I like to catch the first pint or so in a glass jar. It its dark at all, I put one of my super magnets on the side of the jar and see how much stuff moves over to it after a couple of hours.
There is always going to be a small amount of wear particles, but I changed the oil one time and it was black. But not burnt smelling.
A magnet caused fur to form on the inside.
Turned out my front output yoke had worked loose and sand had gotten into the front bearing.
Since it was in the middle of hunting season, I put on a rebuilt and put the old one out in the barn to rebuild.
I think it has been sitting there for about 10 years. Gonna rebuild it just any day now..........
I would say up and down. That's what made me nervous. It was more obvious when I have the drive shaft on and can get some leverage. I could probably use a newer trans and t case the splines mating the two cases are pretty loosey goosey too.
Its probably the bearing. Seems like a little play is normal. There is no shims to set the preload on the input/output shafts.
That's what I was thinking but I don't remember there being any play in there when I put on the new yoke. Gonna have to soft threw this diagrams
