I played on it for a while before getting highcentered. All 4 tires were in the air. I finished installing the Dana 60 at 11:00am. Took a shower and drove 5 miles to this event. I broke in the front gears on this minivan. Everything went well!!
Its going to cost thousands to fix that buggy, full hydro PSC ram, toast. Two nitrogen customs shocks toast. ARB, front gears, gone. Brake and air lines crushed. High angle driveline snaped. Link bars gone also. He ****ed it up bad!!!
He hit the minivan like grave digger!! Front end went sky high, about 12ft straight up. Came down hard. In the pic, you can see by the tires, the pinion is pointing down. It was sweet to watch! Took about 45 min to get him off the car. Well, took about the same for mine also. He had a beefy hydro mount that sheered completely off. About three ft of welds were holding that mount on. Crazy break!
I know, sad huh. I got out without to much damage, there is some, might be bad too. I need a solid ancor point. Others got hammered big time. I need bigger tires and bumpers,sliders, and a big winch! It took 3 8000lb winches and a tractor.
I had custom shafts made a long time ago. They both held up great. Paint is scratched all to hell, but no problems. Trashed the transfercase skidplate, bent the bottom framerail. It is bent up a bit. Bent the bottom rockers a little, a few dents and scratches.
