I'm installing poly body mount bushings on a 84 chevy truck. My question is do I reuse the metal bushing at the top between the body and frame mount? or do i just put the poly bushing between the body and the frame?
On my 76 the front 3 positions reused the factory sleeve(flat washer with a bushing that the new mount slides over) between the body and the new poly mount. The rear 2 there was new flat washers supplied to put between the body and poly mount.
I stuck a screwdriver in between the metal and the old bushing and pushed it apart. BUT i have a southwest truck not much rust. You could also burn off the old bushing with a torch but it is messy and you don't wan to overheat the metal.
