So I have an 81 2WD CCLB Towpig that I'm about to start converting to 4wd.
I'll be adding 63" duramax rear leaves, but that requires removing the saddle tanks.
I have a 91 3/4 ton burb for parts, so i'll use the burb fuel tank.
To facilitate all this I'm going to start all this off by installing a 1" body lift, and since I'm there, might as well replace the 34 year old body mount bushings.
Everything I can find about poly bushings say they increase road noise. I really don't want that. I'll probably be boxing the frame, so I don't care about flex, they'll be lubed so I'm not worried about squeaking, but I really don't want any additional road noise(that kinda defeats the purpose of body bushings, Does it not?!)
I also don't want to(CAN'T) spend $200+ on a set of rubber bushings from LMC, which is the only place I have actually found them in a kit. Their kit comes with bolts and washers, which I'd just chuck as I'll have longer bolts for the BL. Elsewhere I have found single mounts, for $30 EACH!? 30x8=$240?! When a poly kit can be had for $100 or less???
This rig will be getting a Cummins, and spend the vast majority of the time cruising down the road. My goal is to make it as smooth and quiet as possible doing that.
I've searched quite a bit, but the only discussion I can find is whether or not poly bushings squeak...
Who has before/after data on road noise?
I've also seen some topics about installing the 2010+ Hydraulic cab mounts in older GMT800/400 rigs. And I've seen lists that show body mounts applicable to 81-2000 trucks.... Maybe these Hydraulic mounts are an option? Not cheap, I know, as the mounts are like $50 each, but for a 2010....maybe swipe em from a boneyard truck for less?
