docjake
I know that when you are making a bend in tube it increases the size of what you are working on, I am not sure the numbers but I know it does. For example if you start a bend at "A" the length increases to "B" if that makes any sense. I am planning on bending a piece of flat 3/16th at a 90 degree angle what can I expect to add to my corner. For example if I bend it at 12 inches will it end up at 12.25 inches at the outside diameter?
