Power Steering - Need Mods? Or....?
2Dogs
North Plains Oregon
All,
I have never had my PS work very well - after very light work in 4x4 it will go away entirely. Once in awhile it will even try to spool to one side or the other all on its own :eek1:
Here is the setup I will have in a month or so: 37" MTRs on wheels with 3.5" BS (going from 4.25 to 3.5 BS will hurt the situation even more).
Should I be able to run a pump and box combo that will power this setup or do I need to go to hydro assist?
I have an AGR box at the moment, probably why I have had so much trouble. How do you think this box would react to the DIY pump mods?
I already have a cooler installed, did not help.
Sorry if this is the 5028th time you have seen this topic - please point me to relevant posts :wink1:
I am doing the pump mods for my new pump couse my steering SUCKS. I am getting hydro asst soon but just doing the pump now to see if it helps any. now if I could just get the damm pully off...:grind: :hack: :weld: :thinking: :pimp:
You should be able to pull the fitting out of the back of the pump without removing the pump from the vehicle (unless I am missing something different you are doing).
