Curious on other's thoughts. I'm putting a 454 in the crew cab. I installed new oil pan, pump, and pick-up. The motor has been flipped over on the stand several times so most all oil is drained out. It has been almost 6 months since last ran.
I'm thinking I should prime the oil system. I have the tool to do it. I'm debating about whether before or after the motor is in the truck would be better.
Doing it before gives me the advantage of more easily fixing something if there is a problem plus easier access to the distributor hole. Also I can more easily line up the distributor to the oil pump.
Doing it after would allow me to connect the oil pressure gauge. Also wondering if there could be any pitfalls to having oil in the motor during the reinstall.
I feel like priming it on the stand is the best way but then I wonder if I'm overlooking something. I'm sure I'm over thinking this but I want to do it right with this motor.
