problem upgrading from drum to disc
70jimmy
3/4 ton status
Staff member
Moderator
Released from Pueblo, told I belong in Southpark
I recently got a master cylinder and booster for a 1972 1 ton 4 wheel drive which they say is the same for 3/4 by the part number. My new axles are 4 wheel disc. Anyway I put everything on and noticed that the rod going into the back of the booster was tight agaisnt the firewall. I put pressure on it to get it to mount. When I pushed on the brake pedal it wouldn't move.
I measured the bracket and it was like 3 and 1/2 inches from firewall to back of booster. So I went to a friends first gen stash and checked his trucks. I found all but one of his had brackets that were more like 5 and 1/2 inches from firewall to back of booster. I put the different bracket on and voila'.
I also found the truck I took the bracket off had a support rod that went from the upper driver's side bolt on the back of the booster at an angle toward the driver's side firewall and mounted on a stud there. So I stole :o (I mean aquired that also).
Just more screwed up stuff I ran across in my restomod saga!! :rolleyes:
Yup,
My 72 received an upgrade from 1/2ton to 1ton master/booster.
the push rod was way shorter on the 1ton stuff. Now RyanB swaped just his booster and didn't need a shorter pushrod?? Duno why?
Oh and I too have the extra support rod :D
thats odd..
I upgraded and there was no factory mount or location for a support rod...
what am I doing wrong????
:thinking: ......
supersize75k5 said:
thats odd..
:thinking: ......
Well for starters.....your passenger door opens over your tranny.
