Profender coilovers and smoothies
ProfenderUSA
Registered Member
Farmington NY
2.0 Coil overs and 2.0 smoothies
Here are the coilover specs. PM or post for prices.
O/L C/L Travel Piston Rod Shell Upper/Lower Mount
38" 23.5" 14" 46mm 20mm 52mm ⅝” bolt
42” 25.5" 16.5" 46mm 20mm 52mm ⅝” bolt
Springs are available in 100, 150, 200, 300, 400 Lbs/in springs are included in the price.. We can do other lengths, but these are what is in stock, PM with any special requests.
Smoothies are also in stock, we have many different length in stock from 10” travel to 16” travel. They also have a 20mm rod and 46mm piston. They have a ⅝” diameter mounting bolt for more strength.
Bolt kits are available as well, includes 2- ⅝” grade 8 bolts 4- flat washers and 2- top lock nuts.
