Project Cheap Bumper Update mini sliders.
MTBLAZER89
3/4 ton status
Kalispell, MT
The build of my cheap bumper is here. I wanted to trim the lower quarters behind the rear tire and after I did it it seemed like a nice spot for a little body protection. Prolly around $15 dollars for this addition. So I believe I am up to $80 on this project.
Cut
Sliders
Pass side
Driver side
They came out ok. I still have to remove the bumper so I can weld up the rest and put a brace on the inside for side impact. I am not sure if I like how they flow with the bumper, but they'll prolly look better with paint. They are functional though right.:D
Nice :waytogo: The good spot for the brace to the side is right next to the spring hanger . Mine was done so the kicker from the bumper to the frame has a break in it with bolts , so bumper can be removed if need be .
That is perfect and looks great:waytogo:. I might have to borrow that and do it to mine:whistle: :thinking: . Hey pauly do you have pics of your brace I just can pictur what you are saying.
Yes I do . This is how Matt ( az-k5 ) designed it . It ties the side of the bumper to the frame in front of the hanger :D
Well I don't have the materials to make the brace like paulys. I do however have some 1.25 tube that I am planning on running from the forward end of the slider back at an angle to the bumper mounting bracket. That should work for now.
I think that part #00117 http://diy4x.com/misc.htm or something of the like would work well with the 1.25" tube you've got to do it like Pauly's. I think it would be stronger to tie it in by the hanger than back to the bumper itself. :dunno: I would go with the non-shear type, but then you wouldn't be able to slide it backwards.
