Concept was done with Solidworks 2006.
It's a full 3d model that you can pull dimensions from and everything. The only problem is that I designed it around a small block and 700 in the factory location. Then I found a Caddy 500 and TH400 and moved everything 5" rearward.
Anybody have any suggestions for visibility? There's gonna be A LOT of buggy out in front of me and I want to keep it low? Should I build wider and scoot the firewall up and around the block so my feet are next to the motor instead of the bellhousing?
