I pulled an idiot move and ran my Bulldozer out of diesel by sheer stupidity. I usually keep 20 gallons in the machine minimum of a 100 gallon tank. A couple weeks ago we had a bad storm and I thought "when did I last fill that thing up?" I know there was enough diesel in to plow the driveway and there was. Exactly enough for me to go down, come back up and pull back into the yard. It then died. For those of you that know, diesels don't just die. Unless they are out of fuel, and it was. I knew it was going to be a bitch to get back running so I left it. Mad at myself. Filled the tank up the other day when it was warmer and sunny. Remembered an old trick. Cracked all the fittings to the fuel filter then the fuel pump, injector pump and then the no.1 injector. Made up a stopper for the fuel filler neck and pumped compressed air into the tank with the air compressor. Got over and watched for fuel at the filter, tightened the fitting.... Then the injector pump, tightened the fitting. Fuel injector, tightened the fitting....Vrooooom. Damn I'm good. Took about 30 minutes instead of hand priming it with the revolution of the engine or the little primer pump on the fuel pump which would have took hours. Moral of the story, don't be stupid. Fill the thing up.
