Goddamn dude....Do you EVER say the right thing?
If I get my FUBAR'ed stud I drove in, out, I'll lay a golden egg and send it toward Batman's direction
justhorsinaround said:Goodness gracious!!!! You have a known good set of heads. You have the durn thing torn down that far just put the good heads on. A complete set of gaskets (cost less for me than just the head gaskets alone) and you're in like Flynn. Piddle futz with the old heads at your leasiure after you have the truck running again.
Course I'm an idiot so what do I know.
1-ton said:Explain to me what was wrong with what I said? I think the problem is you try as hard as you can to find any little thing wrong with anything I say
tact
One entry found for tact.
Main Entry: tact
Pronunciation: 'takt
Function: noun
Etymology: French, sense of touch, from Latin tactus, from tangere to touch -- more at TANGENT
1 : sensitive mental or aesthetic perception <converted the novel into a play with remarkable skill and tact>
2 : a keen sense of what to do or say in order to maintain good relations with others or avoid offense
synonyms TACT, ADDRESS, POISE, SAVOIR FAIRE mean skill and grace in dealing with others. TACT implies delicate and considerate perception of what is appropriate <questions showing a lack of tact>. ADDRESS stresses dexterity and grace in dealing with new and trying situations and may imply success in attaining one's ends <brought it off with remarkable address>. POISE may imply both tact and address but stresses self-possession and ease in meeting difficult situations <answered the accusations with unruffled poise>. SAVOIR FAIRE is likely to stress worldly experience and a sure awareness of what is proper or expedient <the savoir faire of a seasoned traveler>.
I don't have to try very hard at all to find things wrong with most of what you say.
I'm also gonna have to figure out how to tap the head if I do get it off. maybe I can get a wrench on the end of my tap.anybody else got any ideas on how to get this locktited stud out?
my current attack plan is to grind off the top two threads, maybe throw a little heat from a propane torch at it to loosen the locktite, and try to use the same meathod of tightening the bolt against the stack of washers.
I did significantly clean up the threads with a file, but still can't get a nut on it.........................and its RED locktite, BTW
