Question about AC Compressor in 89 K5
AJMBLAZER
Better to be lucky than good.
Staff member
Moderator
Paducah, KY
I checked the thing following instructions in my AC thread in the Garage and it sounds like my AC compressor is dead. Clutch doesn't seem to engage and it's locked solid while the belt part spins along just fine.:confused:
kennyw has a compressor out of a '86 Suburban with a 6.2L diesel.
http://coloradok5.com/forums/showthread.php?t=272560
Looks similar to mine but I'm wrong with this stuff more than right so I'm asking you guys.
Looking on Rock Auto I see two options listed - the HR6 and the DA6. Which should I have and what do you think his is?:confused:
The other style available in '89 is this one (short flat, larger diameter) like on my '89 K5 with a TBI 350:
Have you looked at the tag on your compressor yet?
Mine doesn't look like that one. Like I said, looks like yours.
Guess I didn't put this pic up earlier. Doesn't have a GM label on it unless it's on the bottom where I can't see it. Thinking it's been replaced.
Here's two more pics I just took of it.
The one I have for sale is the same compressor you need. The brackets are different though.
The compressor you have is a DA6. They're total garbage - just as bad and maybe worse than the R4.
With a little drill work to the existing front bracket and some minor fabbing of a rear support bracket you can install a common ear-mount Sanden or Seltec compressor instead. Here's a pic of mine back when I still had a 6.2:
Hey Max, That's super clean, where did you get the hoses from?
Are those fittings fairly common or are they a hassle to find? We have a couple of good hydraulic hose places here in Bako but not sure how they would be set up with those A.C. ends.
Max, have more details on that swap? I know AC compressors from a hole in the ground, that's about it.
The hose and fittings I get from a local auto AC parts distributor. They are different from hydraulic fittings, so a hydro shop isn't going to carry them.
There's not much in the way of details. You want either a Zexel/Seltec TM-15HD or Sanden SD7H15 compressor. In either case, get the universal ear mount (has 8 mounting ears) with a 2 groove v-belt pulley.
The holes in the front ears won't line up to any on your front bracket, so you will have to mark and drill 3 holes to match 3 of the 4 ears. Mount it with the ears on the front side of the bracket, like you see in my pics. That should align the front belt groove to the PS pump pulley and the corresponding pulley on the crank. The rear belt groove won't be used. Then all that you need to do is fab up a rear support to keep the compressor from wobbling around.
Both of these compressors have a single clutch lead - the other side of the coil is grounded to the case. All I usually do is replace the bullet connector on the clutch wire with a spade and plug it into the hot side of the GM connector, then use electrical tape to insulate it. Nothing fancy, but it works.
Don't bother trying to go to a regular parts house to get the stuff - they won't have a clue. Find a place that sells just AC components. If you don't have one in your area, call Air Components in Mesa, AZ and ask for Rudy. He will hook you up. You will need hose and fittings, of course. Any place in town that can crimp hoses should be able to crimp your AC hoses for you after you get them cut to length.
I know it sounds daunting, but it is actually pretty simple. It's much easier if you have someplace reasonably close to buy the parts and work with you on what you need, but you can still get it done mail-order.
Oh, don't forget to VERY thoroughly flush your condenser and evap, and replace the accumulator and orifice tube.
Yes, I'm digging up an old thread. Getting a "universal" compressor is a neat idea, but didn't some car come with this basic model? What is a good compressor that will take standard GM hoses on the back so we don't need new and/or custom ones? Personally, I would like the option of getting a replacement from Rock auto or a local parts counter when I'm out of town in 100 degrees and the compressor blows.
Also, instead of the TM-15HD, what is the version that has as much displacement as an R4?
I hear the new AC Delco R4s are much better than the older ones, so I'm tempted to get one since I can't find any standard application Sanden-style that won't degrade the performance. Since there is already fab work involved for the install, the universal ear thing is less of a benefit.
EDIT: I ran an old R4 for like 9 years and it always sounded like it was ready to explode, but kept on cooling. When I went serpentine, I swapped another R4 that I got with the other serpentine parts - just because I had it on hand. That thing worked really well and was so quiet I couldn't hear it run. Sadly it is leaking around the body now, which is why I'm looking for options. I'm just saying that all R4s aren't the same.
How does that compare to the HR6 from a G-van / Astro Van? They look similar. Would they bolt right in place of an R4?
...this thread is 3 years old...:whistle:
Don't think MaxPF even comes around any more and since he's not a member he can't post in this thread anymore.
