NewUser
i installed an MSD 6AL box on my 77 K5 and hooke dit up according to instructions...first distributor i used had been setup for dirt track racing(light springs and weights)...when timing was set at 10* and vacuum advance hooked back up it pulled all advance in at one time
swapped that distributor for a new one from work and instaled it, hooked everything up with just stock module(to get truck running) everything was good....came back about 8 hours later and no fire, no spark
tested module and tested bad so swapped in new module, viola! problem solved(so i thought)
drove truck home(finally yay!!) with stock HEI hooked up, did fine and drove great....went to work next day and left truck sitting at home due to loud exhaust that i was going to get fixed after work
came home and experienced same no fire, no spark...took distributor back to work and tested new module...tested fine so swapped for another new distributor...went home and installed it...truck has been running great for past 3 days now
my question is can the MSD box possibly burn out the magnetic pickup in the distributor or did i just get a faulty distributor to begin with?
im wanting to hook the MSD back up but not at the expense of having to swap yet another distributor into the truck...engine has about 60 miles on it so far so i dont wanna screw anything up
any help would be greatly appreciated
