Metalhead47
Ok I know this info is probably here somewhere but I just need a couple quick answers so's I can get parts in by this weekend.
Anyways, 1990 3/4ton 'burb..
Finally started bolting my front axle back in (10b) this weekend, only to discover one U-bolt is an oddball size to the other three
. This is what happens when you tear a project apart then don't touch it for two years. Anyone know what size the U-bolt is nearest the pumpkin, pax side, on a 10 bolt? Ubolt plate looks like 4-1/8th or so, but I also see 3-5/8's listed... help?
Also, pulled the front driveshaft for a quick rebuild, and I noticed that the Ujoints on the double-cardan end look like they're pinned in or something as opposed to circlips. Any insight here? Thanx.
. This is what happens when you tear a project apart then don't touch it for two years. Anyone know what size the U-bolt is nearest the pumpkin, pax side, on a 10 bolt? Ubolt plate looks like 4-1/8th or so, but I also see 3-5/8's listed... help?Also, pulled the front driveshaft for a quick rebuild, and I noticed that the Ujoints on the double-cardan end look like they're pinned in or something as opposed to circlips. Any insight here? Thanx.
