most autoparts stores sell the conversion kit. its 2 adapters for the existing R-12 parts, and they screw on top of them so you can hook the hose adapter to them that comes in the kit. then its a matter of putting the cans of refidgerant and the 1 can of oil into the system. this is the Basic way of doing it.
BUT
seeing i do heating and cooling for a living i would "myself" hook up my vacuum pump to the system first, before i install any 134 into it.. and make sure there isnt any leaks in the system. seeing it was a R-12 truck unless someone unhooked something on the A/C it still should have refridgerant in the system unless it leaked out somewhere. most likely it leaked out of the O-rings on the hoses, or at the dip tube in the system, or possibly a shraeder valve. but not likely. i use nitrogen to pressurize the system and check for leaks after that. and then repair the system, and check again!! you can't be to carefull here!!! once i have verified i don't have any leaks i hook my vacuum pump up again and pull any left over nitrogen/refridgerant out of the system. and then charge it up with the conversion kit, which you want to make sure you install a kit that has OIL!!!!! otherwise your compressor life will be shortened! the kits they sell for this are pretty cheesey at best but do work. i still rely on my 134a manifold gauges and a 25lb cylinder.. but those arent required to do the job.
on the other hand if you take it to someone and they do the convert you should get a warranty out of it, in case 2 weeks down the road you end up turning it on, and get no cooling. you can take it back, and its there problem not yours! just a thought
hope this helps
Ck1500
